1997 Mazda 323 Revving by Itself
MLLAW21
I have a 1997 Maxza 323F.... a few months ago the car started almost binny hopping when i was driving it and it was nothing to do with my clutch control!!! I brought it to the garage and i was told it was dirty fuel and he cleaned it out... 2 months later it has started again and now the car seems to be revving by itself when i turn it on.... can anyone tell me whats going on...
Appreciate any comments before i go to the garage again!!!
Michelle...
Nov 27, 2006 at 10:45 PM
SANDMAN8002
I have a 1998 Mazda B2500. i had the same problem with mine, it actually would carry itself down the road without me pushing the throttle. i changed the throttle position sensor and it fixed my problem.
Dec 6, 2006 at 6:32 PM
COSMO
  • 347 POSTS
One quikc thing to check is to see if there are any tears in the corrigated rubber tube going to the throttle body from the air box. If there are any air leaks there, you will have some strange problems.
Cosmo...Mazda Tech
Dec 6, 2006 at 9:53 PM
Suggested Repair
Inspect the corrugated rubber intake tube between the air box and throttle body for tears or air leaks, which can cause erratic revving.
Conversation Summary
The owner of a 1997 Mazda 323F reported hopping while driving, which a garage attributed to dirty fuel and cleaned. The problem returned, and the engine now revs by itself after startup. Another owner said a throttle position sensor fixed a similar issue on a different Mazda. The expert advised checking the corrugated rubber tube from the air box to the throttle body for tears or air leaks.
