P.S. I had the timing belt replaced and the car serviced on Feb 13. I first noticed the noise on April 11 after a couple of long drives.
1996 Mazda 323 Power Steering Groan
When the noise is happening, open the hood and have someone turn the wheel. Listen closley for the noise source. I would start at the pump.
If it is the pump, and the fluid change doesn't resolve it, it may have a fluid restriction causing the pump to overwork from a pressure problem, or the pump may be going bad. You can try adding a powersteering conditioner such a one made by Lucas. I have had it help on some and do nothing on others. But find the source first.
Suggested Repair
Check whether the power steering fluid is clean and replace it if dirty. With the hood open, have someone turn the wheel and listen for the noise, starting at the pump. If a fluid change does not stop the groan, suspect a restriction or a failing pump; a power steering conditioner may help but is not a guaranteed fix.
Conversation Summary
The owner of a 1996 Mazda 323 reports a loud groaning noise when turning at low speed or while stopped. It is not noticeable when cold but grows louder as the car warms up, with no visible leaks and fluid level varying between minimum and maximum. The expert advises checking fluid condition and replacing dirty fluid, then locating the noise under the hood starting at the pump. If that does not resolve it, a restriction or failing pump is possible, and a conditioner may help in some cases.
