2004 Mazda 323 power steering
2004 MAZDA 323
37,000 MILES • 4 CYL • FWD • MANUAL
DRPR1
  • 24 POSTS
I recently purchased this Mazda from a private party. Today I stopped for lunch and after I started the car and immediately had no power steering. The fluid level is fine, no leaks, belts are fine. What steps should I take to diagnose? Any best guesses?
Thanks
Dec 23, 2007 at 2:44 PM
  • 31,937 POSTS
Hi there,
You will have to have the pump pressure tested. That's a bit tricky on car, but it can be done, if pump pressure is ok, the steering rack will be a fault, i would be thinking a failed pump is your problem.
Mark (mhpautos)
Dec 23, 2007 at 4:22 PM
