1989 Mazda 323 No Spark
MAZDA323
hi my name is tim, i have a 1989 mazda 323 hatchback 1.6 sohc, 5 speed manual, it has 126,xxx miles. i was driving down the street one day and i was at red light and my car just died, i checked the battery teminals, made sure all the spark plug wires were secure. i also checked the wires at the distriutor end and there was blue corrosion, so i bought new spark plug wires and it still wont start. i know its not getting spark because i took a spark plug wire and put a spark plug in it and grounded it and tryed to start it and no spark. my cap and rotor are brand new, i think it might have to do with my coil or some thing, if you could help me out that would be great....Thanks.
Feb 12, 2007 at 8:30 AM
COSMO
  • 347 POSTS
It sounds like you need to have the pick-up and ignighter checked out on yor car. If there is no spark, it is probably the distributo that has gone faulty.
check your local Mazda Dealer..
Cosmo...Mazda Tech
Feb 13, 2007 at 9:56 AM
  • 75,988 POSTS
[quote:d3367e3eed="mazda323"]hi my name is tim, i have a 1989 mazda 323 hatchback 1.6 sohc, 5 speed manual, it has 126,xxx miles. i was driving down the street one day and i was at red light and my car just died, i checked the battery teminals, made sure all the spark plug wires were secure. i also checked the wires at the distriutor end and there was blue corrosion, so i bought new spark plug wires and it still wont start. i know its not getting spark because i took a spark plug wire and put a spark plug in it and grounded it and tryed to start it and no spark. my cap and rotor are brand new, i think it might have to do with my coil or some thing, if you could help me out that would be great....Thanks.[/quote:d3367e3eed]
Could be the coil check its primary and secondary resistances and to include power at the pos. terminal of the coil while key is in On position- could also be one of those that Mr. Cosmo mentioned.
Apr 2, 2007 at 6:19 PM
Suggested Repair
Check the ignition coil primary and secondary resistance and confirm power at the coil positive terminal with the key on. Also have the distributor pickup and igniter tested, since a faulty distributor is a likely cause of no spark.
Conversation Summary
A 1989 Mazda 323 1.6 died at a light and has no spark. New plug wires, cap, and rotor did not restore spark. Experts recommend testing the coil and its power supply, and checking the distributor pickup and igniter.
