Mazda 323 1993
EDALIAN
My car stalls or will not start intermittently. An on-board diagnostic showed 29 blips, and supposedly this means that the solenoid switch is defective.
Where IS this switch? Even a mechanic was not aware of such a switch.
Any help greatly appreciated!
Feb 16, 2006 at 8:33 AM
COSMO
  • 347 POSTS
are you sure it is not a code #2 and #9?
code #2 is a Ne 1 signal failure if I remeber correctly (commonly a dist failure) and I think #9 was a coolant temp sensor (green connector with two wires on intake runner for cyl #2
Get it checked out by your local mazda dealer
Cosmo...Mazda tech
Feb 16, 2006 at 8:45 AM
Discussion summary
Mazda 323 1993
The poster describes a 1993 Mazda 323 that intermittently stalls or will not start. An on-board diagnostic produced '29 blips', which the poster was told supposedly indicates a defective "solenoid switch," but the poster notes even a mechanic was not aware of such a switch. The poster is asking where that switch is located.
Reported outcome: No resolution reported by the poster; they asked for help locating the switch.
Read the original discussion
