2002 Mazda 323 Hand brake
36,200 MILES • 4 CYL • FWD • MANUAL
JOHNWAL
How do I ajust the hand brake
Sep 21, 2010 at 12:57 AM
KHLOW2008
  • 41,812 POSTS
Hi Johnwal,
Here are the procedures.
PARKING/EMERGENCY BRAKE
1. On models with rear disc brakes, depress brake pedal several times. On models with rear drum brakes, start engine and depress brake pedal several times. Stop engine.
2. On all models, pull parking brake lever with a force of 22 lbs. Stroke should be 5-7 notches. If stroke is as specified, parking brake is properly adjusted. If stroke is not as specified, raise and support rear of vehicle. Release parking brake lever.
3. Turn the adjusting nut at the front of the parking cable, on the side of the parking brake lever. After adjustment, turn the ignition switch to ON, pull the parking brake lever one notch, and verify that the parking brake warning light illuminates. Then verify that the rear brakes do not drag.
© 2008 Mitchell Repair Information Co., LLC.
Sep 26, 2010 at 3:55 AM
