2002 Mazda 323
IAN CAMPBELL
Transmission problem
2002 Mazda 323 4 cyl Two Wheel Drive Automatic
I am the owner of a mazda protege for the past six year i have a problen when the vechicle is cold the hold light flashes and the vechicle (holds backs) on low speed diagnostic test was down code P1345 SGC (cam position)sensor circuit malfunction code P0117 ECT-engine coolant temperature circuit low input and code P0710 transmission fluid temperature sensor circuit malfunction what is the solution and what does the hold light have to do with code P1345 AND code P0117 HELP me pl thank u all
Aug 10, 2009 at 1:29 PM
2CARPRO JACK
  • 11,533 POSTS
So it has been doing this for 6 years? Solution may just be new sensors that are listed.The issue may have started with just the trans code, but evolved over time as more things failed, but it wasnt scanned, so you wouldnt know it is simply a list that is growing over time.Try a ECT & Cam sensor.Have the codes cleared, just to see what comes back.The trans code could be bad sensor as well, but could also be the wiring to and from the PCM.The cam code could affect the trans, due to the fact the PCM needs to know what RPM the engine is turning, and it recieves all of that from the cam/crank sensors, and shifts and adjusts itself accordingly
Aug 11, 2009 at 1:07 AM
