2001 Mazda 323 LOCKING DOORS STOPS ENGINE
88,000 MILES • 6 CYL • FWD • MANUAL
C.MNYANJAGHA
I have a 2001 Mazda 323F LXI 1998CC diesel hatchback. When I lock the doors (has central locking) the engine stops running and when the doors are locked the engine cant start. What could be the cause.
The other problem is that the sign that indictes the glow plags are hot enough to start the engine keeps on flashing. It stops when the engine is hot enough and restarted. What could be the cause?
I will be glad if you could assist.
Charles (UK)
Sep 25, 2010 at 10:16 PM
KHLOW2008
  • 41,812 POSTS
Hi Charles,
You need to get a scan done to retrieve for trouble codes and proceed with diagnostics and rectification.
The glow plug blinking indicates troubnle codes have been detected and stored in the engine computer.
Sep 26, 2010 at 3:02 AM
C.MNYANJAGHA
Many thanks KHLow2008. I will have to take it to a garage.
Sep 26, 2010 at 3:50 AM
KHLOW2008
  • 41,812 POSTS
You're welcome and if you require additional information, just post reply here and I will get back to you.
Sep 26, 2010 at 3:59 AM
