2000 Mazda 323 oil light indicator
DONGTALONG
Engine Mechanical problem
2000 Mazda 323 4 cyl Front Wheel Drive Manual
Hi, what could be the problem when the oil indicator doesn't turn off after i start my car's engine?
Feb 26, 2009 at 7:44 PM
  • 75,988 POSTS
You hear any type of knocking noises? if not could be the oil pressure sending unit out of calibration or the oil pump pressure relief valve is sticking and also a wiring problem
Feb 26, 2009 at 8:10 PM
DONGTALONG
Hi, thanks for the reply. I don't here any unusual noise. Also, I would like to know if it's safe to drive the car to the nearest motorshop (about a mile) to have a mechanic check the problem. My wife hasn't changed the oil for a year, will a change oil and tuneup solve the problem?
Feb 27, 2009 at 6:11 PM
  • 75,988 POSTS
You'll be fine -don't forget the oil change and keep up with schedule maintenance
Feb 27, 2009 at 6:13 PM
