2000 Mazda 323 oil light indicator
2000 MAZDA 323
DONGTALONG
Engine Mechanical problem
2000 Mazda 323 4 cyl Front Wheel Drive Manual
Hi, what could be the problem when the oil indicator doesn't turn off after i start my car's engine?
Feb 26, 2009 at 7:44 PM
You hear any type of knocking noises? if not could be the oil pressure sending unit out of calibration or the oil pump pressure relief valve is sticking and also a wiring problem
Feb 26, 2009 at 8:10 PM
DONGTALONG
Hi, thanks for the reply. I don't here any unusual noise. Also, I would like to know if it's safe to drive the car to the nearest motorshop (about a mile) to have a mechanic check the problem. My wife hasn't changed the oil for a year, will a change oil and tuneup solve the problem?
Feb 27, 2009 at 6:11 PM
You'll be fine -don't forget the oil change and keep up with schedule maintenance
Feb 27, 2009 at 6:13 PM
