2000 Mazda 323
MELISSAEVAN101
2000 Mazda 323
air flow sensors only going bad wat is causing this so regular??
Aug 5, 2010 at 6:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
First off, ensure the MAF sensor is indeed bad and not something related to the MAF sensor (passageway etc..).
If the MAF sensor is constantly failing it could be related to a few different things. If the engine is backfiring slightly, this could be the cause of the MAF sensor failure. Also, dirt and grime getting to the sensor will cause it to fail prematurely.
Aug 5, 2010 at 8:24 AM
