ABS and TCS off warning light
61,438 MILES • 4 CYL • 2WD • AUTOMATIC
BRYAN DUNFORD
  • 5 POSTS
Hi, The ABS and TCS warning light some times is staying on when the engine is started and car moving.If I turn off the ignition for 10/15 mins and restart the engine the warning lights go off after a few seconds.
Thanking you awaiting your reply
Bryan
Sep 18, 2010 at 12:46 AM
KHLOW2008
  • 41,812 POSTS
Hi Bryan,
An error has been detected in the ABS system and you need appropriate scan tools to retrieve the trouble codes to proceed with diagnostics and rectification.
Here is a video that shows how
https://youtu.be/rTtAnsOlZU4
Sep 26, 2010 at 4:05 AM
BRYAN DUNFORD
  • 5 POSTS
Hi, Many thanks. It sounds as though it may be expensive before I get to the problem and repair. Since writing the question I drove for three days on about 15 miles journeys each day and the lights never once came on. It is so intermittent that I bet it will not show up on the day I take it in for test.
MOT did not find any fault every thing working OK.
Many thanks again
Bryan
Sep 27, 2010 at 2:41 AM
KHLOW2008
  • 41,812 POSTS
When indicator lights turns on, trouble codes would be stored unless it is a control unit fault.
For ABS problems, appropriate scan tools must be used and not all scan tools can retrieve other than engine trouble codes.
Since problem is intermittent and could be due to loose wirie harness, dirty sensors etc. As it is not recurring now, there is nothing that you need to do now.
Sep 27, 2010 at 6:27 AM
BRYAN DUNFORD
  • 5 POSTS
Thanks for your prompt reply. It makes sense I will try and find a manual our sheet that will show me where the harness & sensors might be.
Thank-you for your help.
Bryan
Sep 27, 2010 at 10:21 AM
KHLOW2008
  • 41,812 POSTS
There are 2 DLC, one at left rear of engine compartment and the other (DLC 2) is under lower left side of dash.
Sep 28, 2010 at 2:50 AM
BRYAN DUNFORD
  • 5 POSTS
Bear with me please what is DLC or what does it look like.
thanks Bryan
Sep 29, 2010 at 6:40 AM
KHLOW2008
  • 41,812 POSTS
DLC = Data Link Connector and it is where scanners are plugged in to retrieve for trouble codes or analyse the engine operations. It is a 16 pin connector, 8 pins in 2 rows. It should look something link the one shown in 2nd diagram.
https://images.2carpros.com/forum/automotive_pictures/192750_EngComp99ProtegeFig01_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_DLC97Mazda626Fig01_2.jpg
Sep 29, 2010 at 7:06 AM
BRYAN DUNFORD
  • 5 POSTS
Thanks that is out of my league it is for the work shop when it goes in.
I am so greatful for your very prompt replies .I have left you feed back.
Again thank you very much If it ever does go in for repair I will let you know the results.
Bryan
Sep 29, 2010 at 7:16 AM
KHLOW2008
  • 41,812 POSTS
Thank you for the feedback and have a nice day.
Sep 30, 2010 at 5:34 AM
NFASORY
I have a Mazda 323. it refuse to start this Morning because of TCF. the light remains on an i can not start
Dec 3, 2018 at 4:08 PM
  • 55,649 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Dec 6, 2018 at 2:18 AM
