1998 Mazda 323 Starting
75,000 MILES • 6 CYL • 2WD • MANUAL
GARYFRENCH
When starting the engine turns over ok but usually won't start. Car will only start if I depress the accelerator whilst turning the ignition key. Once the engine is running the car drives with no problems at all.
Apr 19, 2010 at 8:08 AM
  • 75,988 POSTS
Check the fuel pressure if okay test the coolant temperature sensor and IACV
Apr 20, 2010 at 6:03 PM
