1998 Mazda 323 engine RPM high
1998 MAZDA 323
264,607 MILES • 4 CYL • FWD • AUTOMATIC
NAZIM_0134
nazim sayed
i have one mazda 323 the problem is when you satart the vehicle after 2 or 3 minuites RPM goes suddenly high . please help me.
Mar 28, 2008 at 10:01 PM
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor.
Mar 28, 2008 at 10:54 PM
