1996 Mazda 323 white smoke from exhaust
JAIMO21
Engine problem
1996 Mazda 323 Engine Size unknown Front Wheel Drive Manual 89000 miles
hi i have white smoke coming out of the exhaust from cold start and then goes when engine has warmed up. Engine running fine and smoke dies off pretty quickly any ideas. Mechanic checked head gasket and said was fine.
Feb 2, 2008 at 11:39 AM
BLACKOP555
  • 10,386 POSTS
i belive you just have moisture in your gas, common and when its cold theres alot of it in there and when its being burned off and goes outside it freezes causing you to see the vapors.
if it was a headgasket you would noticed engine problems and it would not go away when warm, it would probably get worse.
Feb 2, 2008 at 11:41 AM
