1994 Mazda 323 Will Not Start
PICKLESD45
Hi, my girlfriend has a mazda 323 hatchback which died about 2 weeks ago and was not getting a signal from the distibutor. I was in the process of changing the distributor when i suddenly started getting spark again so I reassembled the car and sent it on its way a week later the car started acting funny and then died the same way it did before. I then went to the local junk yard and got a distributor and put it in since that point the car has not ran. It has spark, it has 50 lbs fuel pressure and it has ok compression. the timing belt is loose but as far as i can tell the timing is still on. The Pcm is not pulling any codes. Please if anyone can help me i will be greatfull. this car is kicking my ass.
Feb 4, 2006 at 6:16 AM
COSMO
  • 347 POSTS
Make sure you got a distributo for a 323 for one. The protege distributor look just like a 323 one, but will not work in the 323. Also is the spark blue or orange? Orange spark is no good and is not enough to start the car. Also you may have an ignighter issue with the car. This ofter presents itself as a distributor failer. The ignighter is located under the ignition coil on the driver side of the engine compartment and has a connector with three wires and is about the size of a box of matches.
Cosmo...Mazda Tech
I would lean towards a distributor though
Feb 4, 2006 at 6:21 AM
Suggested Repair
Confirm the replacement distributor is the correct 323 unit and not a similar-looking Protege distributor. Check spark quality: blue spark is acceptable, orange spark is too weak to start the engine. Also inspect the igniter under the ignition coil on the driver side of the engine compartment (three-wire connector, about the size of a matchbox), since igniter failure can look like a distributor problem. The expert leans toward a distributor issue.
Conversation Summary
A 1994 Mazda 323 hatchback stopped running after losing distributor signal. Spark briefly returned during distributor work, then the no-start returned. A junkyard distributor was installed, but the car still will not run despite spark, about 50 psi fuel pressure, acceptable compression, and no PCM codes. The timing belt is loose, though timing appears correct. The expert advised verifying a 323-specific distributor rather than a Protege unit, checking whether the spark is blue or weak orange, and considering the igniter, while leaning toward the distributor as the cause.
