1992 Mazda 323 Fuel Problem?
NANDJABRAHAMS
Engine Mechanical problem
1992 Mazda 323 4 cyl Two Wheel Drive Manual
Ok my mazda starts and idles fine but upon giving it some throttle it badly misses and wont rev at all. It gradually come about as i was driving and couldnt get it above 60km/h as it just runs sparadically. ive changed all filters thinking they may of been blocked but it wasn't to be. PLEASE HELP!!!!!
Aug 29, 2009 at 11:59 AM
  • 75,988 POSTS
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Aug 29, 2009 at 12:07 PM
