1992 Mazda 323 Engine Miss
221,000 MILES • 4 CYL • FWD • MANUAL
GAYAN
Hi, there was a oil leak from tappet cove oil seal and we replace oil seal and fixed the issue. also we cleaned the spark plugs and fixed them back due to oil leak to plugs. after this my care is always makes miss we checked the spark plug wires also.
Anyone can guess what is the issue.
Thanks,
Gayan
Jul 5, 2010 at 9:06 PM
KHLOW2008
  • 41,812 POSTS
Hi Gayan,
Guessing is not going to solve the problem.
If the miss is intermittent, the most likely cause would be the spark plug and/or related parts.
Did you ohm the spark plug wires to check if any is bad?
While cleaning the spark plugs, did you check the spark plug gaps?
Are the conditions of the spark plugs good?
Jul 6, 2010 at 2:20 AM
