1992 Mazda 323 change over
BRETTO
Engine Performance problem
1992 Mazda 323 4 cyl Front Wheel Drive Manual
will a mazda familia engine fit onto the gear box of a mazda 323 bg. i want to put the familia turbo ingine in but not sure if it is compatible
Mar 19, 2009 at 2:36 PM
RICH CRITES
  • 75 POSTS
I would suggest that you change the engine and transmission. You may need a stronger transmission to handle the turbo, you will also get better gear ratio with the trubo transmission.
Mar 31, 2009 at 6:34 AM
