1992 Mazda 323
BRUCEHT
  • 1992 MAZDA 323
1992 Mazda 323 Two Wheel Drive Manual
How difficult could it be to convert a Mazda 323 from manual to automatic transmission?
Friday, June 4th, 2010 AT 4:58 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
There is a lot to do, Transmission, drive plate, exhaust may be a bit different, drive shafts, counsel and shifter, shifter cable, loom, ECU, may be a different dash cluster, remove the pedal box and install the auto pedal box, on top off all that, I am unsure if the Auto mounts are in alignment with the manual mounts on the frame, I have never seen it done, so I am unsure even if it is possible to do it.
Mark (mhpautos)
Friday, June 4th, 2010 AT 7:00 AM
