1991 Mazda 323 Clutch
1991 MAZDA 323
TIAMARIA
Transmission problem
1991 Mazda 323 4 cyl Manual 120000 miles
My clutch is really loose, no pressur, and when I go to shilfit it starts to grind. A friend says I may just have a leak and should add some fluid. I cannot seem to find anywhere to add the fluid.
Nov 14, 2008 at 10:25 AM
The clutch master cylinder is nearby the brake master cylinder similar to each other-check the fluid level if okay -check the clutch slave/servo at the trransmission-both okay and no leak-you need a new clutch assy.
Nov 14, 2008 at 12:57 PM
