1989 Mazda 323 Throttle Position Sensor
JRDARING
  • 8 POSTS
Electrical problem
1989 Mazda 323 4 cyl Front Wheel Drive Manual
Im not getting power to the throttle position sensor.I had the car running and it was ok then it wont true over again then i check the fuses not there so i let it sit then when out later ans it started about to time then it wont start so i check it getting fuel and the fuel inj are working so i check throttle position sensor and there is no power .can u please help me out with this thanks jim
Mar 23, 2010 at 10:54 AM
  • 75,988 POSTS
Check and test the blue and yellow wire back to the computer connector #2 pin C
Mar 23, 2010 at 11:02 AM
JRDARING
  • 8 POSTS
i check the blue and yellow on computer and i got nothing were do i go now. thinks
Mar 23, 2010 at 11:58 AM
  • 75,988 POSTS
The computer when southbound on you -it suppose to give the reference voltage to the TPS
Mar 23, 2010 at 3:36 PM
JRDARING
  • 8 POSTS
are u saying i need to replace the computer for it and do u know were i can find one at are is there a way to bypass it thanks for all ur help
Mar 24, 2010 at 12:36 AM
  • 75,988 POSTS
Check the same color wire at the airflow meter for power if it has by pass it from there they share the power circuit-
Mar 24, 2010 at 7:15 AM
JRDARING
  • 8 POSTS
i aready check it there the blue and yellow wire dose not have power there either but there is a green and white wire that has power there and its 12 v. thank
Mar 24, 2010 at 7:38 AM
JRDARING
  • 8 POSTS
i believe its the air mass sensor has going bad is there a way to bypass it. well thank u for all Ur help it help me out a lot.
Mar 25, 2010 at 3:40 AM
