1989 Mazda 323 Head gasked
1989 MAZDA 323
JOSEPH_GOULD
Engine Mechanical problem
1989 Mazda 323 4 cyl Two Wheel Drive Manual
Am working on replaycing the head gasked on this Mazda 323, 1.6 i have removed everything out and i still can't take the head out, once i removed the valve cover i didn't see any regular looking bolts instead there were some star looking bolts in between the rocking arms are those the bolts i need to remove to get the head loose and out? ....thank you
May 31, 2008 at 6:53 AM
FERMECH
  • 14 POSTS
You need to remove the cams, making sure you note were the caps go.
Then you will see all the head bolts.
Jun 3, 2008 at 2:59 PM
