1989 Mazda 323 FUEL PUMP
JHOUSDEN
Electrical problem
1989 Mazda 323 4 cyl Front Wheel Drive Automatic
CAR WONT START.
NO FUEL FROM PUMP.
12VDC TO PUMP
IS THERE A POSSIBLE OTHER PROBLEM THAN FUEL PUMP.
NOT CERTAIN WHERE FUEL RELAY IS IN CAR.
JAMES R HOUSDEN
Nov 5, 2008 at 6:16 AM
RICHARDJOE
  • 8 POSTS
if you have 12 volts at pump its not relay check the yellow ground wire.
you can also pull the pump and bench test it.
Jan 4, 2009 at 1:40 PM
