1989 Mazda 323 changing the water pump
1989 MAZDA 323
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
PINKONE
after the water pump was changed, it ran ok for one day, than the next morning i crank it up and gas started pooring out of the exhaust and tail pipe. i readjust the barmetric regulator and it stopped for 3 minutes and started back again. Do you think the timing need to be reset, had to take the timing belt off to put the water pump on.
Jun 22, 2010 at 1:42 PM
Hi pinkone, Welcome to 2carpros and TY for the donation
The only way for that to happen is your injectors or the fuel pressure regulator leaking or excessive fuel pressure
Jun 22, 2010 at 3:33 PM
