1989 Mazda 323
SLOBBER
  • 1989 MAZDA 323
  • 4 CYL
  • MANUAL
  • 18,000 MILES
My mazda will start and run perfectly but soon as it warms up abot 10 - 12 kilometers it cuts out turn it off an it will run go a bit further same problem then will continue turn it off then turn it on away it goes, I have cleaned all the carb, replaced pump filter checked all the fuel linesand all is good, I suspect the electronic ignition, there are no cracks in the distributor cap rotor arm I have also replaced the coil
Friday, September 26th, 2008 AT 3:20 AM
Next time it dies out immediately check for spark and fuel then comeback and tell me what's missing.
Friday, September 26th, 2008 AT 6:26 AM
SINGING SWAN
I had the same issue with my car. Turned out it was air in the radiator system and the car had to be "burped".
There was a hole in the radiator that kept letting air into it. I repaired the radiator, let it run for a while with the radiator cap off until no more air bubbled out and never had that problem again. Good luck
Wednesday, December 17th, 2008 AT 3:24 PM
