1988 Mazda 323 electronic.ignition
PATRICK.HATCH
Electrical problem
1988 Mazda 323 4 cyl Front Wheel Drive Automatic 140k miles
ign.failure,,when,i,check,for,spark,from,the,coil,to,the,
cap,i,get,only,one,spark,for,each,time,i,reset,the,key,and,crank,the,engine.over,,,have,bench-tested,the,coil,and,have,replaced,coil,wire,also,cap,and,rotor
Feb 12, 2010 at 8:05 AM
KHLOW2008
  • 41,812 POSTS
Hi patrick.hatch,
Thank you for the donation.
Did you check if the timing belt is intact? With distributor cap removed, crank and see if the rotor turns.
Feb 12, 2010 at 11:18 AM
