1986 Mazda 323 Intermittent starting problems
16,700 MILES • 4 CYL • FWD • MANUAL
LAKEHOUSE4629
Wouldn't start..Had been running perfectly. Checked for spark. There was no spark. Replaced ignition coil,cap,rotor,and ignition wires(one had rubbed against metal airbox causing it to make a small arc mark.After repair, Car ran fine for two months.Then it wouldn't start again, waitied 30-40 minutes then it started and ran fine. Now it's worse.Sometimes I can't start it for days then it starts right up and runs perfectly, then it shuts off and won't start.Wait a few days and it starts right up, runs great. Then it does it again, any ideas? Thank you..!
Hey Guys,
10/5/08
I've been pouring over my manual and there's nothing called an "Ignition module". Do you mean Igniter? Mine is part of the Airbox...? Help
Oct 4, 2008 at 3:07 AM
MERLIN2021
  • 17,250 POSTS
Ignition module...take it out and have the parts store check it. Or get a module tester
Oct 4, 2008 at 4:06 AM
