1986 Mazda 323 Engine bucks
1986 MAZDA 323
366,000 MILES • 4 CYL • FWD • MANUAL
BKROLL
Engine bucks at upper RPM range when trying to accelerate. Mostly in the higher gears 3rd through 5th
Jul 6, 2009 at 10:03 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 6, 2009 at 10:09 AM
