2008 Mazda 3 Ran over a parking lot barrier
38,000 MILES • 4 CYL • 4WD • AUTOMATIC
STACINATOR
I was in a target parking lot and I accidently drove over the barrier for the barking space when I was trying to pull through. It scraped really loudly. I stopped when it was about halfway in between my fron and back wheels. I then backed up to clear it through the front so that it wouldn't hit my bumper on the way out the back. I took it to a car place right after and they said nothing was leaking. Everything seems fine when I drive and I haven't noticed and sounds or difference in control. I worry though that maybe I bent something important or something. Should I be concerned?
Apr 29, 2009 at 4:44 AM
2CARPRO JACK
  • 11,533 POSTS
It is possible nothing was damaged.If the shop said nothing was leaking, then about the only other thing to do woul b e to have the alignment checked to see if it bent a control arm....or if the exhaust is bent
Apr 29, 2009 at 6:40 AM
STACINATOR
So what does it mean if I bent a control arm? What will that cause and about how much is it to get that fixed? What does it mean if the exhaust is bent? Like I said I only went about halfway between the front and rear wheels, I kept it away from the muffler.
Apr 29, 2009 at 7:10 AM
2CARPRO JACK
  • 11,533 POSTS
It would cause the alignment to be of which will rsult in tire wear and the car pulling while driven.Have it checked before worrying about anything. dont tell them what happened, just have the alignment checked that way it is like a blind study, they wont be as apt to try to sell you something unless it is actually bad
Apr 29, 2009 at 7:35 AM
