Torque Specs when Replacing Front Brake Pads
2007 MAZDA 3
40,000 MILES • 4 CYL • 2WD • AUTOMATIC
TANDJTHOMAS
2Car Pros,
Can you tell me the torque specs for the front caliper bolts and the caliper bridge bolts for the 2007 Mazda 3i? So far,my web search is drawing a blank. Also, can you recommend a good DYI repair manual for this model? Haynes does have one and I haven't found a Chilton's one for sale, either. Mazda Owner in Atlanta.
Aug 1, 2010 at 1:25 AM
KHLOW2008
  • 41,814 POSTS
Hi tandjthomas,
Here is a guide that will walk you through the steps and a diagrams below to help you with the job on your car. The bolts are 25 to 30 foot pounds
Minimum front disc pad thickness .................... 2.0 mm (0.079 in) min.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Cheers
Mar 15, 2021 at 11:19 AM
