Tires and Wheels problem
2007 Mazda 3 Two Wheel Drive Automatic
Have a flat tire on the front right wheel and cannot take the tire off. I have no manual to refer to. Any special lugnuts, or can you offer suggestion what to do.
Sunday, January 17th, 2010 AT 4:53 PM
MECHANIC
Hi there,
Thank you for the donation,
There is nothing special to do, remove the trim cap if fitted and use the wheel nut spanner in the boot, the wheel nuts are R/H thread so turn them anti clock wise to undo, some times the alloy rims stick on the hub and they need a bit of a kick to loosen them, make sure that car is jacked up on a firm level surface and never get under the car on a jack only, use chassis stands.
