2004 Mazda 3 sterring wheel shimmy
2004 MAZDA 3
49,400 MILES • 4 CYL • 4WD • AUTOMATIC
MENDE
My daughter hit a curb and bent two rims and ruined two tires. I purchased 4 new tires and rims and had them installed, balanced and aligned.The car steering wheel shimmys andl shakes at certain speeds. It comes and goes also. I looked under neath but no noticable damage except one strut has a dent on the outside wall. Could a damaged strut cause this, or a bent tie rod. How can you tell if a tie rod is bent?
Is it safe for her to drive?
Aug 13, 2008 at 12:04 PM
  • 31,937 POSTS
Hi there,
If something is bent a wheel alignment will pick it up, i would be getting a reputable aligner to inspect this asap as it is not all that safe to drive and you may destroy your new tyres quickly if not repaired.
Mark (mhpautos)
Aug 13, 2008 at 12:14 PM
