2004 Mazda 3 Headlight ON Warning Chime
BROWNE02
Electrical problem
2004 Mazda 3 6 cyl Front Wheel Drive Automatic 50.000 miles
How do I repair or replace the Headlight ON Warning Chime that is not working
Aug 18, 2008 at 3:33 AM
SAUSAGEO
I had this same issue and it was fixed by replacing a fuse in the fuse box located under the passenger glove box.
Just wedge yourself down there, pull off the cover and rotate the white panel so you can see the fuses.
The fuse I replaced was labeled ILLUM on the cover of the fuse box. Replaced with a new 7.5 A fuse and all was fixed.
Mar 21, 2013 at 4:20 PM
KHLOW2008
  • 41,812 POSTS
Any update on this?
May 11, 2013 at 4:59 PM
