2004 Mazda 3 Fully depressing the caliper piston.
2004 MAZDA 3
65,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGPARRAN
I have removed the old rear brake pads. I've obtained a large enough C- clamp to depress the piston. It appears that I've can't get the piston to depress anymore yet I don't have enough room to put on the new pads and reinstall the caliper.
updated 11/28/09
I was able to run down this tool from Auto Zone and it made all the difference in the world. I have a new problem however. I have figured out how to attach the pad with the clip on it to the caliper piton, however, I can't figure out how to attach the retainer once the pad is on the piston. Please advise.
Orlando
Dec 22, 2009 at 8:42 AM
DOCFIXIT
  • 18,828 POSTS
Need a tool that rotate piston to retract see diagram tool F043 002
https://images.2carpros.com/forum/automotive_pictures/198357_Grafic_3_81.jpg
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_275.jpg
Dec 22, 2009 at 8:59 AM
DOCFIXIT
  • 18,828 POSTS
See diagram
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_287.jpg
retainer clips over caliper then it will press against the mount to keep pad from rattling. Trick hear is to only take apart one side at a time so you have a template
Dec 29, 2009 at 12:36 AM
