Gurgle noise when pressing the brake pedal
8,400 MILES • 1.4L • 2WD • AUTOMATIC
PEGGYP29
When i push the brakes my car gurgles and i cant figure out what is wrong.
Jul 10, 2020 at 9:18 AM
  • 110,248 POSTS
Are the brakes working properly? Also, is the sound loud enough to record and upload for me to hear? Could the sound be a vacuum like sound?
The brakes are assisted by engine vacuum. If there is a leak, you may be hearing a noise. The power brake booster is under the hood mounted to the firewall on the driver's side. I attaches a pic below and circled the booster and the vacuum hose that goes to it.
Have a helper start the engine and apply the brakes while you check to see if that is where the sound is coming from.
Jul 10, 2020 at 11:35 AM
Does this do this sitting still or only when you are moving and you hit the brakes?
Gurgling is not a typical noise that the brakes make so I am thinking it has more to do with the cooling system but can you get a recording of this noise? That may help us identify what this could be. Thanks
Jul 10, 2020 at 11:42 AM
