Metal on metal grinding from front drivers side tire
2003 CHRYSLER SEBRING
12,900 MILES • 2.4L • 4 CYL • 2WD
CAT4
There is a metal on metal grinding from front drivers side tire. pulled tire off brake rotors are very loose. tighten up noticed bolt missing from caliber on bottom. will replace that,but grinding still there. can you help?
Jan 28, 2019 at 4:26 AM
CAT4
Also forgot to tell you grinding only when step on brake pedal. Pads have been checked they are good and rotors look good.
Jan 28, 2019 at 4:36 AM
Good afternoon,
It does sounds like the pads are hitting the rotor. I would remove the wheel again and remove the caliper and rotor and inspect.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
If you can, post pictures of the rotors and pads.
Jan 28, 2019 at 6:11 AM
CAT4
Okay, thank you.
Jan 28, 2019 at 6:31 AM
You are welcome.
Always glad to help.
Jan 28, 2019 at 6:50 AM
