may be oxygen sensor, engine light came on
155,000 MILES • V8 • 2WD • AUTOMATIC
SQUEETER
Just had complete harness and gauge panel removed and replaced due to dash fire every thing in and under dash completely destroyed. It was returned yesterday, took it for test drive and engine light came on. took it back to the mechanic he ran a scan and believes it may be the oxygen sensor. Should this had been caught due to the original problem or is this a totally new problem having nothing to do with the wiring fire problem?
Sep 27, 2017 at 5:07 AM
STEVE W.
  • 15,390 POSTS
Could be either one. No real way to tell. If the light was off it may be a new code or it may be due to the fire causing issues in other places due to shorting and voltage going to places it normally does not.
Sep 27, 2017 at 11:13 AM
