Master Window control panel not illuminated?
57,000 MILES • 1.2L • 4WD • AUTOMATIC
SANDRE
Master window control panel not illuminated when turning on headlights, infotainment buttons.
May 16, 2026 at 8:19 AM
  • 55,710 POSTS
If all the other lights work it sounds like the switch is bad, I would swap it out which should fix the problem.
May 17, 2026 at 9:24 AM
SANDRE
Now it's a bigger problem. I found out that my day running lights aren't illuminating also, along with the master control Panel button backlights (except for the power window).
May 20, 2026 at 8:29 PM
  • 55,710 POSTS
Okay, please check of any other items are not working, lets check the system fuses first, this video and guide will help. Make sure you check the fuse panel under the hood and the interior fuse panel as well.
https://www.youtube.com/watch?v=G-xNK79Wa-w&pp=0gcJCQMLAYcqIYzv
and
https://www.2carpros.com/articles/how-to-check-a-car-fuse/
Please go over these guides and get back to me.
May 21, 2026 at 7:58 AM
