Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Isuzu
Rodeo
Brakes
Line
Replace/Remove
Master cylinder replacement
2001 ISUZU RODEO
200,000 MILES • 3.2L • V6 • AUTOMATIC
JAMESMMJ
MEMBER
1 POST
I have replaced the master cylinder, but I cannot get the brake lines to bleed. What is the proper bleeding procedure on my vehicle?
May 11, 2017 at 12:42 AM
HMAC300
Experienced Mechanic
try a power bleeder first it may work otherwise a mechanic is going to have to use his scanner to open valves on ABS unit so it can be bled.
May 11, 2017 at 2:40 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
