Master Cylinder or Power Booster?
200,000 MILES • 3.8L • 6 CYL • AUTOMATIC
KARENMGUIN
I dont know if its master cylinder or power booster. Put front and rear pads on the bled the brakes. During bleeding the back brakes didnt seem to have the pressure the front did. But anyway my pedal goes to the floor, before i bled them the pedal went to the floor and got to the point that i rolled out in the lane of traffic. So i bled them (1st time never bled brakes before) and it worked for a minute . Now it goes to the floor but it stays put just way slower to stop the car. I pump them a little while stopping. Master cylinder has fluid and has maintained fluid ...however i found a leak that i think is coming from the seal where the master meets the booster.. So help i dont know which it is??? Thank you Karen
Aug 28, 2016 at 4:36 AM
KARENMGUIN
Rebleed the brakes right?
Aug 28, 2016 at 5:11 AM
KARENMGUIN
Oh and thank you! I was right ????
Aug 28, 2016 at 5:12 AM
RENEE L
  • 1,260 POSTS
Yes, bench bleed the master before installing it the instructions will come with the new unit, then install it and re-bleed the system, yes you were right :)
Pleas let us know how it turns out so it will help others.
Sep 1, 2016 at 2:40 AM
