Master cylinder cap?
2007 HONDA CRV
136,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
TJMOWBRAY
  • 85 POSTS
Is the master cylinder cap supposed to be loose my brake pedal feels soft I've recently replaced pads all way around and noticed that when I put fluid in reservoir the cap doesn't feel tight like any other vehicle I've owned haven't had the vehicle very long and trying to go over it and repair things as needed
Apr 22, 2026 at 12:17 PM
  • 55,433 POSTS
The cap should be tight on the master but this will not make the brake spongy, it sound like you have a brake caliper slide that is sizes or there is air in the lines, please check for brake fluid leaks at each of the wheel as well. This guide can help with the calipers
https://www.2carpros.com/articles/discover-why-automotive-brake-pads-wear-unevenly
And this guide will help with the air in the lines and ABS
https://www.youtube.com/watch?v=nQRnKyVyMuQ
Let us know what you find.
Apr 24, 2026 at 1:02 AM
