Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volkswagen
Caravelle
Drivetrain
Transmission
Clutch
Master Cylinder
Master cylinder
2000 VOLKSWAGEN CARAVELLE
269,868 MILES • 2.6L • 5 CYL • 2WD • MANUAL
JAMESKEKANA
MEMBER
bought a new master cylinder and I have installed it but the car is not clutching at all. what could be the cause?
Mar 18, 2018 at 4:09 AM
Experienced Mechanic
Did you bleed the system of air?
Mar 18, 2018 at 7:50 PM
JAMESKEKANA
MEMBER
actually yes I did bleed it but not clutching at all or maybe I did not bleed it correctly
Mar 23, 2018 at 4:53 AM
Try re bleeding, get a friend to help, hold down the pedal and open the bleeder close bleeder befor lifting pedal repeat until no air comes out
Mar 23, 2018 at 6:01 AM
Add image or video
Ask a new question
Engine won't start
