Where are the Mass airflow sensor/map sensor/IAT sensors located?
90 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
PATTYBOY
  • 6 POSTS
Need to locate all three of the above-mentioned sensors. hope you can help.
Thank you,
Patrick
Oct 21, 2021 at 2:02 AM
SQM
  • 6,383 POSTS
The mass air flow sensor is located at the end of the air tubing by the air filter box.
The IAT and MAP sensor is located under the air box.
I have attached diagrams and pictures below for your reference.
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Oct 21, 2021 at 3:13 AM
PATTYBOY
  • 6 POSTS
I can never thank you enough for the information and diagrams you afforded me; God bless be safe! Patrick. P
Oct 21, 2021 at 5:20 AM
SQM
  • 6,383 POSTS
You are welcome.
Oct 21, 2021 at 6:06 AM
