Stalling randomly when the idle gets too low
283,000 MILES • 5.3L • V6 • 2WD • AUTOMATIC
MCGRINDER22
My SUV has been stalling when I start to come to a stop or slow down to make a turn or just randomly when the truck starts idling too low. I was told that I needed to change the mass airflow sensor, but I just changed it and the truck is still doing the same thing as it was before. What could be some other causes of this?
Mar 27, 2019 at 7:05 AM
SEVAG P
  • 405 POSTS
Hello thanks for using 2CarPros.
it seems the idle control valve is the problem or vacuum leak that leans up the mixture and engine stalls.
As a first step you must read the fault codes:
Run our guide for engine stalls:
https://www.2carpros.com/articles/stall-at-idle
https://www.2carpros.com/articles/engine-stalls
Our guide how to replace idle control valve:
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
and checking for vacuum leak.
Please send us feed back if you get any fault codes.
Thank you
Mar 27, 2019 at 7:33 AM
