Mass air flow sensor wiring diagram needed?
469,890 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
JIMMEJIA
I replaced the Mass air flow sensor on the car listed above, with no change. I was told to check the wiring ground coming from the wire harness goes where. thank you
Mar 24, 2023 at 12:33 AM
  • 55,782 POSTS
Here are the engine and mass air flow wiring diagrams in the images below. I have included a guide on how to check the connection as well.
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Mar 24, 2023 at 12:19 PM
