when I start the car up and let it warm up and when I start to drive for about 30 minutes or what not the engine stalls at the red light.
Oct 3, 2024 at 4:06 PM
✓Experienced Mechanic
What are the code numbers please? I have seen the MAF short out and cause stalling, I would unplug it to see if it makes a difference. Here is the location and how to get the codes for us:
Image (Click to enlarge)
Oct 4, 2024 at 5:13 AM
AKATONY
MEMBER
1 POST
How do much does it cost to fix it for from cutting off?
Oct 4, 2024 at 9:38 AM
That is hard to say until we figure out what the problem is. I could be as simple as a loose fuse and as involved as a rebuild PCM. Did you try unplugging the MAF sensor? Also, what are the code numbers?
