Mass air flow sensor connector wiring?
100,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
BIGRICK00719
Upon removing the maf sensor connector the connector became detached to the wiring. I am able to but them back but I need the proper wiring sequence. I saw one for a 2 liter engine but my car has a 1.6 liter engine is the wiring the same.
Mar 10, 2026 at 7:38 AM
  • 55,604 POSTS
Do you mean MAP sensor? Also, does this car have a turbo? Here is the wiring to the MAP sensor this car does not have a MAF sensor. Ken
Mar 11, 2026 at 1:56 AM
BIGRICK00719
I meant Mass airflow sensor the car is a 1.6 liter engine and doesn’t have turbo
Mar 11, 2026 at 2:06 AM
  • 55,604 POSTS
Is this a euro car? If so we dont have the info on that, all Kia's in the US have a MAP sensor, can you please upload an image of the sensor in question?
Mar 12, 2026 at 1:47 AM
BIGRICK00719
I’m sorry I was told the engine was 1.6L by the owner after further inspection the engine is 2.0L. That should make a big now. Thanks for the help.
Mar 12, 2026 at 2:34 AM
  • 55,604 POSTS
There is only the MAP sensor for the 2.0 liter as well, can you send an image of the sensor so I can see it?
Mar 13, 2026 at 2:24 AM
BIGRICK00719
This is the part my question is about
Mar 13, 2026 at 2:36 AM
  • 55,604 POSTS
If this car has it it will be in the air intake tube near the throttle body or air filter box.
Mar 14, 2026 at 3:50 AM
BIGRICK00719
It never answered the original question which is what is the correct wiring sequence for the connector because the connector were disconnected from the internal wiring.
Mar 14, 2026 at 4:37 AM
  • 55,604 POSTS
Sorry, is this a Euro car? everything we have here does not say this car has a MAF sensor that is why I wanted an image of the part in the car.
Mar 14, 2026 at 4:38 AM
