Mass air flow
7,500 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CHARLES RICKARD
Car will only run when MAF is disconnected, but rough. I changed the MAF from my 2002 Crown Victoria that is running. I had it in the dealers shop and they replaced the fuel pump and said the injectors needed replacing. I had it towed back home and cleaned the injectors. I read some where on line that the ECU could be bad. There were no codes at the dealer after changing the fuel pump.
Feb 16, 2018 at 12:00 AM
Good evening.
Lets back up a little.
Was there a code that led you to the mass air flow?
Feb 17, 2018 at 9:51 AM
CHARLES RICKARD
No code, seen other people unplug the MAF and their car ran. Just thought I would try it.
Feb 19, 2018 at 11:28 AM
