Marker lights and tail lights not working
50,000 MILES • 6.4L • V8 • TURBO • 4WD • AUTOMATIC
RIC GORDON
No power to lights, don't know which fuse to check or what else to check.
Apr 24, 2019 at 12:10 PM
  • 110,248 POSTS
Welcome to 2CarPros.
The fuse is located in what is called the smart junction box (SJB). It is located on the passenger side foot well. I attached three pics. The first shows location, the second is a close up of fuse 22 which powers the parking lamp relay. The third picture is a legend of the fuses located in the box. The wiring schematic indicates the lighting relay to be in the SJB also, so if the fuse is good, check that.
_______________________________
Here are some general links for testing and using specific tools you may or may not need. I'm just adding them in case you do need them.
Let me know if this helps. If you need additional information, let me know.
Apr 25, 2019 at 11:05 AM
